joelyn's avatar
joelyn
RULER reading???
Need to drill a hole for a hitch pin Have the 5/8in hitch pin and need to drill a hole a bit bigger. The size I need is 2 lines after the 5/8 in on the below pictured ruler. What size drill bit do I need?
thanks
Not sure why the picture so blurred. not like that on photo bucket.. but what size drill should I use to insert a 5/8in hitch pin in??
  • You have the arrow on 1 and 11/16 which is 1 and 1/16 inch bigger then 5/8 inch. I would drill the hole 5/8
  • I've done several of those. I used a 5/8" bit and the pin fit perfectly. I wouldn't use anything bigger.
  • Need a clearer picture than that. Did you look at the post before you posted it? You can't read any numbers except the 2.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 19, 2026
