CJW8
Jul 14, 2015Explorer
Since you admit you have little electrical knowledge, don't try this yourself. Get an electrician. Is your 30 amp breaker in the main panel a double breaker? That means twice as wide as a normal 15 or 20 amp breaker. If so you are half way there. The rest involves removing panel covers and you shouldn't do that unless you are qualified. This is where you need an electrician.
Here is what I did to run both AC's.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
