camperpaul
May 23, 2013Explorer
You can do it if:
If your rig is wired for 50 Amp service:
You have a correctly wired 50 Amp RV outlet into which you can plug the RV.
If you need an extension cord, use only a 50 Amp RV extension cord.
If your rig is wired for 30 Amp service:
You have a *correctly wired 30 Amp RV outlet into which you can plug the RV.
If you need an extension cord, use only a 30 Amp RV extension cord.
* Make sure the electrician knows how to wire an RV outlet.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
