2oldman
May 23, 2013Explorer II
Olive600 wrote:Nothing like an argument about the mysteries of electricity to divide friends.
.. running the AC for my 2005 B Touring Cruiser Gulfstream off my house current can burn out the AC's air compressor. I've also been told that's not true, that the worst that will happen if there isn't enough current is that a fuse will blow.
the difference of opinion has turned into some very bad feelings between friends.
You've been given some pretty lousy advice. Yes, it *can* be a problem IF your extension cord is too long or small. But what will usually happen then is the a/c won't even start. And that thing about the 'fuse'.. well, first off you have breakers, not fuses, and they blow when there's TOO much current (amps). And I really don't understand CamperPaul's advice either.
To be as safe as possible you really need a voltmeter. Measure it without the a/c running, then measure it with it running. If there's much of a drop (like 5 volts) then you probably shouldn't be running it. Also, if the connecting plugs get hot after a few minutes, then absolutely don't run it.
"Please respond".. lol, like anybody has to say that around here!
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
