time2roll
May 23, 2013Nomad
Olive600 wrote:
I've been told that running the AC for my 2005 B Touring Cruiser Gulfstream off my house current can burn out the AC's air compressor. I've also been told that's not true, that the worst that will happen if there isn't enough current is that a fuse will blow. Unfortunately the difference of opinion has turned into some very bad feelings between friends. I'm still shaking. Please help me understand if you can. I'm new to all this. Evidently as an older, single woman I will be lied to and cheated at every turn. At least that's what I'm being told. (Yes, I'm so upset that I'm sniveling 8-) )
Thanks
The grey area between yes and no is low voltage.
If voltage remains at ~108+ inside the RV you are are good to go.
So depending on your set up either yes or no advice could be correct.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
