I_am_still_wayn
May 23, 2013Explorer
Olive600 wrote:
Unfortunately the difference of opinion has turned into some very bad feelings between friends. I'm still shaking.
You will hear all kinds of answers from the armchair electricians. The truth is yes you can do it. And yes you can damage your A/C. Let me explain.
You need enough electricity supplied to the A/C- that will mean usually between 110 to 130 volts. Optimum will be 120 volts. You will then need enough amps to actually run the A/C. Plugging the RV into your house outlet will give you the correct volts. Plug the RV cord directly into a 20 amp circuit from your house with very little, and preferably nothing else electrical running and you will have enough amps for your A/C. If you have to use an extension cord, 12 gauge, but preferably 10 gauge no longer than 25 feet will work.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
