PUCampin
May 23, 2013Explorer
Olive600 - I have a very similar situation at my house. I park my Trailer on the side of my house where there is a standard receptacle. My Trailer has the standard 30A 120V cord and plug. I like to use my trailer for a guest house for my aunt, I like to have the fridge on, and very occasionally use the air conditioner. Here is what I do and why.
1. Most of the time I just want to charge the batteries, run the lights, and the fridge. These things do not use a lot of power. I use a short adapter cord, sometimes called a pigtail, that I plug into the receptacle on the side of my house and plug my RV cable into that pigtail. This works great as long as I only charge the batteries, run lights and the fridge. This receptacle on the side of my house is part of a larger circuit that includes my daughter's bedroom, son's bedroom, the living room and some lights in the house. With all these other things on the same circuit, if I tried to run the AC in the trailer I would have problems.
2. If I really need to run the AC this is what I do. I unplug the pigtail from the receptacle on the side of my house, go into the garage an plug it in to the receptacle where my washing machine is plug in. This is a dedicated circuit, required by code. There is nothing else on this circuit, just the washing maching (and dryer if you have a gas dryer) I do have to add a short heavy duty extension cord because it is further away. I can then run the AC and whatever else in the trailer with no problems.
So why can I run the AC when pluged in to the washer outlet but not the one on the side of the house? Because the washer outlet is dedicated. There are no other outlets, no lights, nothing else. The one on the side of the house shares the circuit with a bunch of other stuff, any of which can be on at the same time.
If I try to turn on the AC while plugged in to the side of the house, there will be too many things on and it can trip the breaker. However, it MAY NOT automatically trip the breaker, but can cause the voltage to sag too low which can damage the AC. This is why you have been told plugging in to a regular outlet will burn up the AC, because it is possible.
Plugged into the washer outlet, with nothing else needing power, the voltage will not sag much if at all, it will not damage your AC, and will not pop the breaker.
If you try to run the AC, the fridge on 120V, the water heater on 120V, charging the battery, and running a microwave, yea you will probably trip the breaker, but with a little common sense it is no issue.
Hope this helps some.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
