Olive600
May 23, 2013Explorer
PUCampin wrote:
Depending on the age of the house, outdoor outlets might be on a dedicated circuit, and other garage outlets may also be on a dedicated circuit (even if the washer is inside the house) My home was built in 1981, and code at the time did not require outside or garage outlets to be on dedicated circuits, but I believe more recent code does require it. So if the house is newer you may have that already. If not, find which breaker controls the outlet your RV is plugged into. When it is off, see what else in the house is off. Walk around with a small desk lamp and try plugging it in to various outlets to test. Most likely to be affected are outlets inside rooms adjcent to the outside outlet.
If you aren't a teacher, you should be. I'll do all this tomorrow morning. Thanks again.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
