time2rollagain
Jul 23, 2024Explorer II
Yes my Go Power 2000w inverter runs my Dometic 13.5 with ease. For about the same space and weight of my 4x GC2 I DIYed a 1200 Ah LFP battery. Easily holds voltage above 13.0 under extended heavy load.
Although my 4x GC2 would run the A/C for at least a few minutes while testing. Never tested how long they would run the A/C.
StirCrazy
Jul 24, 2024Moderator
did you add an easy start? i have the gopower 2000watt inverter in my 5th and have never been able to run it.
I would imagin the age of the batteries could be playign a part also if that is so, to many unknowens and the OP isn't coming back to answer it seams.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
