Muddydogs
Dec 03, 2015Explorer
Just hook the compressor up to the battery and compress away. No need to unhook anything from the battery's. Only caution would be it won't take long to run down a battery with this compressor so if you needed anything more then a quick top off you could run the battery down fast. If your truck is wired to charge your trailer battery's when hooked up then plug in your trailer lights and start your truck so the trailer battery won't be sucked dry.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
