Colonel_Monk's avatar
Colonel_Monk
Running Dual Black Tanks.....
Howdy
I'm designing a compact travel trailer which is focused on extended dry camping and crossing the USA.
I'm liking the layout that I have but due to small size I've got the combo shower/toilet in the front of the trailer. This is fine except for I don't want the 42 gallon black tank in the front of the trailer. For weight balance I need to move it aft.
Though I have been thinking about a composting toilet, sounds to me like they can be a real hassle, especially if west of the rockies.
So I'm coming up with a plan to make this work, bear with me....
I'm thinking of placing a small black tank directly under the RV toilet. Probably something in the "several gallons" range. (they do exist)
Plumb that black tank to a permanent marine-style macerator pump.
Plumb the output of the macerator pump to my main black tank located near the axles.
When small tank is full, flip the macerator switch and pump it out into the main black tank.
Main black tank will drain just as all normal black tanks do.
I'd probably also put a 3" drain drop on the mini tank just in case there are problems it can still be emptied and flushed for "service".
Anybody done something like this? Comments?
Thanks
CM
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 16, 2026
