dougrainer
Oct 13, 2015Nomad
Low 12 volt will cause the Furnace fan motor to NOT run to correct RPM's. When that happens, there is a "Sail Switch" that MUST be closed for current to flow to the control systems. When the fan motor eventually slows due to low DC voltage, the Sail Switch will open and the furnace burner will shut off. Doug
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
