TracksideNW's avatar
TracksideNW
Running Lights Won't Work - Wiring Help Needed Please
OK I just bought a 2008 Lance 830 camper. Everything except the running lights work fine. So I accessed the battery box where the leads from the plug come in and thought I could just check for continuity by putting one lead on the correct terminal on the plug and then check each wire back at the battery box until I got continuity, but all the wires at the battery box show continuity except the power lead. This is the case for the other terminals on the plug.
So much for my basic electricity skills. I did check my truck and the marker terminal is producing power, so I know the truck is good.
Anyone know which color lead is the one for the marker lights, and if there's perhaps a fuse somewhere on board that I should check? Also wondering if there is a better way I should be troubleshooting this.
Thanks for your help!
  • RoyB's avatar
    RoyB
    Explorer II
    I have one of these TEST ADAPTERS in my tool box to plug into the 7-WAy TRAILER CONNECTOR on the truck. This adapter has LED LIGHTS for each of the OUTPUTS coming from the truck side. If it doesn't work here then you know the problem is on the truck side. A great tool to have when having problems.
    I got mine from ETRAILER but see them on AMAZON and I imagine some may available at auto parts stores.
    ETRAILER.com has a lot of information including diagrams on their web site for everything trailer. Good place to go for info...
    I am not aware of any fuses on the trailer side for any of the SAFETY lights or functions. I have found some WD40 sprayed into the 7-way socket before I plug into it helps some keeping the blades clean.
    My truck does have fuses in one of the DC FUSE PANELs for the 7-way trailer connector. Also the key ignition has to be on for some of them as well...
    I am just assuming the truck side connections for TRUCK CAMPERs are the same as used with RV Trailers here...
    Roy Ken
  • JaxDad's avatar
    JaxDad
    Explorer III
    First off, using standard colour codes, the brown wire is running lights.
    Before you get much further though, your profile doesn't show what truck you have, Ford uses a double fuse setup. There's a second fuse box that has seep rate fuses for the trailer harness. If you have a dually, the marker lights on the rear fender flares are connected to the trailer harness so you can easily see that the trailer has no marker lights if you blow a fuse.
    I'd start by testing that there's power coming out of the plug you're connecting the camper to.
  • it *should* be green for marker lights, white for ground, black for +12, red for left turn, brown for right turn.
  • my ford had a seprate fuse for the trailer running lites on the passenger side theres a fuse box number ten on my 2005 ford.
  • The more modern trailers like your '08 Lance are usually equipped with a good set of wires and lamp fixtures. Also there probably isn't a lot of oxidation.
    Here's how I would troubleshoot the issues: Determine that the truck's harness has power at all the terminals and that the harness has continuity to ground. Here is a page of the different trailer electrical schedules----Harness schematics and wire color conventions. Next determine that the trailer's harness has all of the wires connected and in the right locations on the umbilical plug. PLug in trailer harness and observe for power at any of the unlit light fixtures. If you have power, there is a ground issue. If no power at the fixture, there is an open in the circuit. I'd venture a guess that 9 times out of ten, marker light issues are related to a faulty ground. Check real good for the ground wiring to the front fixtures and the first going back along the driver's side. That is where the chain wiring usually begins.
    Good luck with the lights. Lance makes a fairly stout trailer so it is probably a minor issue.
Having RV issues? Connect with others who have been in your shoes.24,301 PostsLatest Activity: Aug 15, 2025
