- wa8yxmExplorer III
Skibane wrote:
You'll need a low-pressure electric fuel pump (to replace the one on the Onan you yanked out of the RV), along with an adjustable fuel pressure regulator to reduce the fuel pump's 4-5 PSI output to just a small fraction of a PSI (which is what the pressure coming out of a gravity-fed fuel tank would normally be).
With most makes of generator you are correct.
With a HONDA. they put on on the generator at the factory.
As someone posted up thread the HONDA is designed to suck fuel from an external "Extended run" tank. they even showed a photo of the set up.
Honda sells the tank and the "Modified" gas cap needed to use it.
The procedure is fill the "on board" tank. and the external. replace the original gas cap with the "extended run" cap and it sucks the extended tank dry. You then swap caps back (Running off the on board) While you run to ye old fuel pump to refill the extended tank.. Can run a long. long, long time that way.
TO THE ORIGINAL POSTER
Be sure to put a shut off valve line (two in fact) in the line from the RV's primary tank. One manual and one "Quick Disconnect" type to insure the line does not express fuel when the tank is filled. - jjrbusExplorerI have used the external tank for years. My concern is the vehicle fuel system is pressurized, would it push fuel through the Honda? Just does not sound right.
- SkibaneExplorer IIYou'll need a low-pressure electric fuel pump (to replace the one on the Onan you yanked out of the RV), along with an adjustable fuel pressure regulator to reduce the fuel pump's 4-5 PSI output to just a small fraction of a PSI (which is what the pressure coming out of a gravity-fed fuel tank would normally be).
This prevents the generator engine from running rich or flooding out, due to excessive fuel pressure.
For safety's sake, the electric fuel pump will need to be connected so that it shuts off if the generator engine dies for any reason.
Many portable generators have a 12 volt DC "battery charger" output that can be used for this purpose - basically, the battery charger output powers the fuel pump whenever the engine is running.
You'll also need to add a "prime" bypass switch that allows the fuel pump to be manually turned on for a few seconds while starting the generator. - BobboExplorer III just use an extended run fuel system. The 6 gallon tank lasts a couple of days at moderate amp draw.
Extended Run System - opnspacesNavigator III don't see why not. The Honda has a fuel pump so I imagine it would work just fine with a modified fuel cap like those for running extended tanks.
- LwiddisExplorer III wouldn’t consider this idea. Others might. I want my TV’s fuel supply not to have “stealth” drainage.
Having RV issues? Connect with others who have been in your shoes.24,195 PostsLatest Activity: Feb 05, 2025
