- shastagaryExplorerhe did pull fuel from the rv fuel tank as the compartment he used was the original generator compartment and the fuel line was already there.
when he filled the generator tank to full it would over flow into the catch bottle so he could see when the generator tank was full he later installed a night vision camera and a switch inside by his camera monitor to see the overflow bottle so he could release the momentary fill switch and stop the pump.
he had a hour meter and a compartment fan plugged into the generator also. - jjrbusExplorerInteresting setup with the predator. Youngster seems to have put a lot of thought into it, yet he did not pull fuel directly from the vehicle tank. Wonder what his thinking was?? Is he old enough to drive?? LOL
- shastagaryExplorerthis guy set up his predator generator to be refilled with a manual activated electric fuel pump and a catch bottle to see when its full
he later installed a night vision camera and a inside remote switch to fill the generator.
youtube Generator Project - RV Living - BobboExplorer IIIKeep in mind that propane only has about 80% of the BTUs per volume that gasoline has. You have to derate the generator by about 20%. So a Honda EU2000i that is 2000 watts surge and 1600 watts continuous is only 1600 watts surge and 1280 watts continuous on propane.
- SkibaneExplorer IIAnother option would be to install a propane conversion kit on your portable generator, and plumb it into one of the RV's existing low-pressure propane lines.
- jjrbusExplorerI am not a mechanic, the only experience I had was when I had my gas tank cleaned and lined. I had the tank bolted in and most of the hoses hooked up. Took a break and when I came back out gas was coming out of one of the small lines that was not hooked up. I removed the gas cap releasing the pressure and the gas stopped flowing. I had put about 5 gallons of gas in the tank to check for leaks.
- Grit_dogNavigator III
jjrbus wrote:
On another forum someone posted about running a Honda EU2200i off the original fuel line from the removed Onan. I have been using the mighty little Honda forever and never heard of tapping into the vehicle fuel supply. Does not seem right? Any input on this.
If you don't have a RV where there is already an aux fuel line and pump to a built in generator, it would be very prohibitive IMO.
If you do, then it would still be quite involved to make it a Hands Off system, although it could easily be a handy storage tank and gas pump to fill a remote located generator. - valhalla360NavigatorModern vehicle fuel systems are sealed for emissions reasons and get fussy if that seal is lost. How exactly would you be tapping into the tank?
The outboard tank with honda transfer cap really makes far more sense. - wa8yxmExplorer III
jjrbus wrote:
I have used the external tank for years. My concern is the vehicle fuel system is pressurized, would it push fuel through the Honda? Just does not sound right.
The vehicle fuel system is not pressurized... There is a pump (External to the ONAN generators but very close to it)( specific to that line. the line pre-that pump is not pressurized might be slight vacuum in fact.
A Separate line to the main engine IS pressurized. But that is for the Motor home's motor. - SkibaneExplorer II
wa8yxm wrote:
With most makes of generator you are correct.
With a HONDA. they put on on the generator at the factory.
As someone posted up thread the HONDA is designed to suck fuel from an external "Extended run" tank.
Drawing fuel from a tank sitting right next to the generator isn't the same as drawing it through several dozen feet of fuel line to a tank mounted somewhere else on the RV.
Depending on the particular RV, there may also be some additional restriction from a fuel filter.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
