mkirsch
Sep 10, 2015Nomad II
Crabbypatty wrote:
Thats interesting if it works,but what about the cost? If it cost so much more could you have upped the genny size. Next the 8 amps of charge is not a lot, so are you charging or slowly killing your battery as the a/c pulls more than 8 amps.
The 8 amps AC output from the Honda 1000 translates into about 60 Amps of 12VDC charging capacity through the inverter.
You could use the 12V output from the Honda 1000, but that would be foolish when you can use full output of the generator to power the charging circuit on the inverter.
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
