DrewE
Oct 19, 2016Explorer III
Home Skillet wrote:Boon Docker wrote:
Start the vehicle with the house battery then take neg cable off vehicle battery and drive the 50 miles and get a new battery.
Very bad advice.
Taking the battery out of the circuit will cause voltage spikes that can damage components.
On many RVs (with relay-based isolators), the house battery remains connected to the system while the engine is running. In such a design I would not hesitate to disconnect the chassis battery.
I had a car for awhile where one of the battery terminals had worn loose and would occasionally vibrate off the battery post. Quite possibly I was lucky, but it never caused any damage to things. It was noticeable when driving that something wasn't quite right; when at a stop light, for instance, the headlights would dim a good bit and the wipers slow down since the alternator couldn't produce enough power at idle speeds.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
