Boon_Docker
Oct 20, 2016Explorer III
Home Skillet wrote:Boon Docker wrote:
Start the vehicle with the house battery then take neg cable off vehicle battery and drive the 50 miles and get a new battery.
Very bad advice.
Taking the battery out of the circuit will cause voltage spikes that can damage components.
BAD advice.
Modern 12V systems are NOT designed to be run without a battery.
The house batteries will still be charging will the vehicle is running which will act the same as the chassis battery.
