jake2250's avatar
jake2250
Rust!! How to deal with it??
Just bought a complete crabbing set up from a friend, 15' inflatable, traps,gps,depth finder,30 hp motor,the whole deal,, Only issue I have is the trailer he gave me is Very rusted from salt water,, nothing rusted through, but heavily rusted,,,, My question is,,,, Sand Blast or wire wheel?
KDS makes a paint they claim you can paint over rust,, and Rustoleum has Rust Stop paint..
Common sense is to remove old rust,,, but has any body delt with heavy rust and what is the fastest most economical solution??
HBF has a portable blaster for $40,,, but the KDS paint is really expensive,,,
If I could just paint over it and forget it,, then thats the easiest, But easiest might just be a waste of time???
Oh yeah, I have purchased new bearing and race sets, along with a new wiring and LED light set, tires and wheels are on order..
I even need to go to DMV to get a new plate,,, rusted.
I plan to tow it behind my trailer, about 120 miles one way to the coast. All I will be putting on the trailer is crab pots and a storage bin,, not much more than 500 lbs at the most,, I will haul boat and motor in the bed of the pick up..
  • If you're trying to save a few bucks, you should make sure it's structurally sound and then blast it or use the rust-covering paint. I saw a larger trailer failure the other day where the tongue broke in half about five feet aft of the hitch. The tongue was apparently rusted through from the inside, so the areas you can't see might be compromised.
  • My question is about this, is if he took such great care of the Trailer, did he flush out the motor with fresh water every time he took the boat out of the water? probably not. that would be the sale breaker there.
  • MTNHNTR wrote:
    From someone who has had a painted boat trailer used to launch in salt water - get a galvanized trailer and not worry anymore.
    MTNHNTR, I know and I really appreciate the great advice, But I am looking at maybe $200 in materials,,, I am retired and Dungeness crab season starts back up in November, so my thought is,,,,, a project,, a reason to buy more tools,, so time is not to much of an issue,,, rust is heavy but surface only,,, Drive train is a no brainer,,less than $100,,, A new Galv trailer is $500 minimum,,, I hope to make this work for less than the price of a Harbor Freight cheap trailer...
    I once took on a job repainting a wrought Iron fence as a kid,,, allot of sanding and wire wheeling,,, but it looked good and I got paid,,, I know this thing will hold all of my crap,,, the amount of effort is what I am gauging it on...
    I got a killer deal on this whole set up,, so I am trying to keep it real...
    back of my mind is saying,,, Just buy a new trailer,,,, but wallet is saying,,, You can do it....
    yes or an aluminum one with galvanized everything else
  • From someone who has had a painted boat trailer used to launch in salt water - get a galvanized trailer and not worry anymore.
  • A used boat trailer that has seen only fresh water can be bought for $150 which may be a cheaper and longer lasting option.
  • I know you are on left coast, place in PA called Eastwood. I also play with old cars besides camping and their rust proofing products are great. Like above I used POR on floorboards of old car and it ate up the rust. Try Eastwood.com
  • best way is to sand or bead blast, prime and paint, if you cant do that then a stiff brush to ensure the rust is fully removed or it will continue
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
