Gdetrailer
Apr 16, 2014Explorer III
crcr wrote:
Hi, One of the tail lights on our TT burned out. It's a stop and tail light 3157 bulb with two elements, with the wedge shaped plastic base. This one is a CEC3157. I was looking online for a replacement, and found that I can get LED replacements for less than the standard automotive bulbs. My question is, would these LED replacements work correctly as a plug and play for tail and stop/turn signal functions?
HERE is a link to some of these LED replacements on ebay.
Thank you in advance.
The real answer is no, LEDs retrofitted into in a fixture which was solely designed for incadescent bulbs often results in less than satisfactory results.
LEDs are very directional in light dispersion and some manufacturers attempt to make them omnidirectional by putting a bunch of low wattage LEDs in a "corn cob" design to overcome the directionality issue. The light still tends to be uneven and will end up being less bright overall.
Then add in that Ebay is FULL of fly by night fleecers selling what ever junk they can get their hands on..
Just go and buy the correct incadescent bulbs, they will work better in your fixtures and typically can be had for under $6 for TWO bulbs..
If you want LED tail lights then buy new purposely made replacement fixtures with LEDs (you CAN buy surface mount LED fixtures), they will be brighter.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 29, 2026
