Gdetrailer
Apr 17, 2014Explorer III
Crcr writes “I have bought lots and lots of various styles of LED's over the years on ebay, converting the interior lights of every vehicle and TT that I have owned, and they have been very bright (much much brighter than the incandescent bulbs they replaced) and held up very well. And I just buy the lowest price from very high feedback major sellers of whatever item I am purchasing. I also have bought various other items on ebay for years and years, finding the quality of the products on average to be as good as the products I buy anywhere else. Besides, if I should receive a shoddy quality product from an ebay seller, I have recourse through ebay. Ebay is very "buyer friendly" and they will refund you in full including shipping if you are dissatisfied, even if perchance the seller will not.
I just ordered two LED 3157 replacements on ebay. Cost shipped was $3.12, which is about what one incandescent 3157 costs. And as I said, if the product turns out to be inferior, I have easy recourse through ebay.”
INSIDE lights and OUTSIDE lighting is TWO DIFFERENT matters.
INSIDE LIGHTS, ANYTHING GOES, your are more than welcome to replace them with anything your heart desires..
OUTSIDE LIGHTS are a whole nother ball of wax and come under FEDERAL DOT regulations..
Replacing the incandescent lamps with LED lamps in a fixture which was designed to meet or exceed certain optical specifications with incandescent bulbs may no longer meet those specifications. LED lights will make for a very bright spot and the remaining portion of the lens may end up being dark or not lit at all. This can make for a very dangerous situation for the drivers behind you and even yourself..
The ONLY ways I would recommend replacing a incandescent bulb with LEDs would be to either replace the ENTIRE FIXTURE or use a LED BULB which bears the FMVSS 108 certification mark..
My suggestion to you is perhaps you should read up on the Federal regs…
HERE
“Here is my original question from my original post:
... would these LED replacements work correctly as a plug and play for tail and stop/turn signal functions?
In other words, I was asking if anyone knew if these LED replacements that are sold for the multiple functions of tail light and stop/turn signals, do actually work correctly for the multiple functions. No one answered that, so I decided to order some and find out for myself.”
If the “bulb” part number is designated using the same main part number as a incandescent equivalent it “should” have the correct socket and functional characteristics BUT keep in mind that you ARE buying non qualified CHINESE IMPORT bulbs which may or may not be 100% “compatible” in fit, form or function…
It is also a well known fact that LED manufacturers tend to WAY OVERSTATE the lumens. They can get away with that simply because LEDs have an extremely bright center spot and THAT is what they measure.
There are literally 100s of thousands of Chinese “importers” posting all kinds of junk on Ebay and MOST are not going to be worried about the quality nor fitness of the junk they sell to you. Since there so many of these cheap imports it is virtually impossible to say whether LED “X” will work for you or not..
Basically my answer of NO, it isn’t going to work is a very valid answer even if the bulb lights as it should, the amount of light scatter may not be all the great and potentially create a hazard to other motorists.
LEDs improperly used in the wrong application can be more of a hazard.
Buyer beware.
Don’t be so cheap. My life and others out on the roads are not cheap so don't treat us like a throw away Kleenex or paper towel..
HERE
Buyer beware.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 29, 2026
