wnjj
Sep 07, 2020Explorer II
enblethen wrote:
Step 1: connect green straight to the black wires from fixture
Step 2: Are the lamps LEDs? Yes, possible polarity issue. Reverse black and whites to lamp holders:
Step 3: Get 12 volt test lamp. Make sure you have 12 volts to the fixture.
Step 4: verify that there is not another switch in circuit.
What part of the NW are you in?
x2 on step 4. From the original description it sounds like maybe the switch is on the light fixture itself? If that’s the case, the black wires may have been all wired to the same mushroom connector, intentionally bypassing the switch there and there’s another some place else.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
