dougrainer
Aug 28, 2019Nomad
kmb1966 wrote:DFord wrote:
Are you level both front to back and more critically side to side?
Are the fans in the back operating properly?
yes. we are on concrete level slab, jacks down, and leveled
its hot outside, and inside temp is 90.
Inside the fridge 2nd shelf is 40. Freezer at 5
Make sure you test the temp with a glass of water and NOT the air temp in the refer or the temp of the shelves. You can get an actual temp of the evap fins if you go into the on screen diagnostics. The evap fins will be 10 degrees cooler than the actual temp of the water in the refer. Also use a digital thermometer. Do not use an IR thermometer. Doug
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
