sgip2000 wrote:
road-runner wrote:
Need to pull new wire. Codes requires 2 hots, a neutral, and a ground from the main panel.
Unless I'm interpreting this incorrectly it sounds like it's saying that 120 volt sub panels are not allowed. I don't think that's the case.
I was referring to is panels that are designed for 240v.
Thanks for clarifying that. I thought the panel the OP posted a picture of was strictly 120 volt. Another piece of info, however, a few years ago a contractor installed for me a subpanel built for 240, as a 120 volt subpanel. It's labeled that it's a 120 volt panel, and to not install multi wire branch circuits. Flew right through the inspection.
