I'm going to park my RV behind a fence along side my house on what is now part of my lawn. The entire lawn is irrigated and I will remove some sprinklers, redirect some and add some so that the RV won...
Forget removing the grass unless you need the soil some where. Lay down back plastic "mulch" , perforated membrane for drainage and blocks sunlight to kill grass beneath and prevent new sprouting through the gravel. Garden department
Try to find a few 24 in. square patio blocks (about 2 inches thick). They may crack but too heavy to move much. two on each side for rear and one each side for front. You only need enough fill to make the wheel tracks level and hold the membrane down.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
