I always check the park outlet, before plugging in. I recently stayed where my meter was showing 121-122. I know that neutral to ground should be 0. I was getting a reading of 0.6, would this be ca...
Ground are not perfect. I saw an interesting item on Utube about grounds approx a year ago. He drove in a 20' rod first and still had resistance. He drove in 3 or 4 rods to really start getting the resistance down. For amateur radio I have 4 grounding rods still not perfect for grounding my antennas. Electricians only drive in 1 rod. I suspect if conditions are dry you may measure some floating voltage. I would be more concerned if I measured 120 volts Vs .6 volts.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
