I always check the park outlet, before plugging in. I recently stayed where my meter was showing 121-122. I know that neutral to ground should be 0. I was getting a reading of 0.6, would this be ca...
If you unplug every RV the ground-neutral voltage will probably drop to zero. As long as power is flowing in the shared neutral there is probably some voltage drop and you are picking that up on your meter.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
