chiefward's avatar
chiefward
RV Plumbing Pipe
I;m going to reroute the galley tank discharge to the black and grey water discharge pipe. Is the rv black pipe the same as Home Depot white pipe? If not, where can I get the black pipe?
  • Home Depot should have it, it is standard pipe used for drains. :)
  • They are the same size. Last Spring I had to replace the p-trap under the bathroom sink. It was the same size as the white p-traps used in your home. You can use the white.
  • From the galley sink it's just going to be 1.5" standard ABS.
  • Thanks for y'all quick response. I just didn't remember see the black ABS at HD. Will do a search at my HD for ABS. ( I didn't know what it was called.)
    On some TTs the black ABS is a odd size. Not available at Home Depot etc. I got mine from a RV parts supply business.
    It's been a few years since that project, so I can't recall the size. I also don't know how widespread this is in the industry.
  • White is PVC and black is ABS. They can be coupled with the correct fittings or rubber couplers. Since you asked such a basic question, I suggest you do a lot of research before you tackle this and get some help from a friend with plumbing experience.
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 19, 2025
