dougrainer
Jul 07, 2020Nomad
jaycocamper62301 wrote:dougrainer wrote:
http://www.rvcomfort.com/pdf_documents/8330b331_8330b335_thermostat.pdf
Have fun:) It is a tedious process. Doug
Went thru all that yesterday and resetting doesn't seem to activate the front zone 1. Where do I start dumping money? Thermostat? Control box? or new heat pump?
In response to replacing the HP. If your Radio or AC system in the car failed, would you replace the engine:B Control box is first, but you need to verify the wiring between the 2 Units. It is rare for a ZC tstat to be bad with your symptoms. Have you tried swapping the jumpers for Zone 1 and Zone 2 to make the rear Zone 1 and the front Zone 2? Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
