Master6969420's avatar
Aug 05, 2020
Rv sewer hose won’t fit
I bought a new rhino sewer hose for my motor home and the little clips are to small to twist onto the clips on my rv. The clips on the hose and rv look exactly the same but the ones on the hose are a little smaller.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    It fits. Tight but it fits.
    I went with a competitor's product.
    Titan from Valterra
    I like it better than rino flex
    Oh and if it's a motor home where the connection is inside a bay (Even if it's a trailer) you might like a special wrench to help tighten/loosen the connection and cap.
    The link is an example. I found them cheaper and more expensive and you can usually buy 'em locally
    very good sewer cap/hose tool
    Even if it is sold for a different use.
  • jdc1's avatar
    jdc1
    Explorer II
    Just grind or file it down until it fits.
  • Read the box. Are you sure you didn't buy a sewer hose extension? Did it come with all the fittings?
  • Do you have one that fits?
    What color is the pipe on the rig? Years back there was odd white pipe system that took special connectors.
    Make, year and model of your rig?
