SkiSmuggs
Mar 07, 2017Explorer
SoundGuy wrote:SkiSmuggs wrote:
Before doing that, does anyone know where the crank ups leak and how to prevent leaks?
The Winegard Sensar Installation Instructions provide detail on lubricating this antenna so it doesn't leak. If you've not followed these procedures on a periodic basis since owning your antenna it's no wonder you experienced leaking. I've done mine several times and haven't had any issues at all.
Thank you! The one issue I have is lubricating the quad ring. I tried something like that on my previous trailer and end up with a poorly functioning crank assembly as it didn't go back together as well as it was prior. The first two lube steps look easy.
Alright! I found the entire procedure on YouTube.
Winegard Antenna Maintenance
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
