Johno02
Mar 07, 2017Explorer
In addition to the spray lube mentioned, I use a bit of silicone lubricant designed for swimming pool fittings. Just put a glob on the shaft when I replaced it, then another glob on the gears. Seals and Lubricates. I keep a tube around just about all the time. use it for sewer hose connections, and lots of other things..
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
