SkiSmuggs
Mar 07, 2017Explorer
BFL13 wrote:
Usually we hear about the leak being from the "boot" on the roof coax not covering the hole where the coax goes down in. Not sure how you can tell where the water is coming from by seeing the leak inside.
I found that some putty helps keep the boot in place.
I have the Jack replacing the batwing. The Wingman sticking out would hit a roof fitting on ours--measure for that before buying one (as they advise)
The leak seemed to be right from the crank handle, BUT, the boot had traveled up the cable a few inches. I wasn't sure that was the problem as there was caulk, but thanks for the heads up.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
