SkiSmuggs
Mar 07, 2017Explorer
Johno02 wrote:
In addition to the spray lube mentioned, I use a bit of silicone lubricant designed for swimming pool fittings. Just put a glob on the shaft when I replaced it, then another glob on the gears. Seals and Lubricates. I keep a tube around just about all the time. use it for sewer hose connections, and lots of other things..
Thanks, that sounds like a good idea.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
