Dutch_12078
Mar 26, 2017Explorer III
For those with clearance issues for the Wingman add-on or Sensar IV replacement head, there are a couple of possible options. Trimming the end element off the Wingman to shorten it a bit is one option, although it will degrade the performance some. Still better than no Wingman though. Another option that's more labor intensive would be to remove the mounting screws for the Sensar base and rotate the entire assembly slightly until it clears the obstruction. Reseal and reinstall the screws and your good to go. The inside ceiling plate should also be rotated to match.
