jrnymn7
May 04, 2015Explorer
If necessary, you could engineer in some line loss/voltage drop, but usually the crappy oem (under-)wiring does that for you... (that's likely why converters run at 13.6v, not 12.6v).
I can see your inverter getting the full voltage, but have you checked how much voltage is actually getting to the 12v lighting, 12v panel, fridge's control board, etc.?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
