jrnymn7
May 04, 2015Explorer
Daily Top Charging is not required, if that is, in fact, what you're doing? If the bank is being maintained in the higher SOC range, and is getting fully charged (replenished) daily, there will be limited sulfation, and therefore no need to top charge daily. Watch for tiny bubbles during abs, as this is an indication of gentle gassing and de-sulfating. Personally, I only top charge if the bank has been allowed to sit at less than 100% for any real length of time, like when self-discharging while not in service.
You must check SG levels, as this is the ONLY accurate way of determining SOC, and/or whether or not top charging an/or eq'ing is required. Familiarizing oneself with their bank is best done when the bank is out of service... and then one can compare that to the effects of daily usage.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
