LittleBill
May 04, 2015Explorer
Chandalen wrote:
Ok so I totally understand::
The dc-dc keeps the 12v power systems of the camper at a constant 12.x volts. Ie.. fridge, heater blower, lights etc.
Whats the amp max of it?
I assume that your inverter comes right off the batteries, and is tolerant of whatever power is being applied to charge them?
Chandalen,
it will accept a range of voltage on input, prolly 10-36v(guess) it will output either a set voltage or a adjustable range you can set.
his model is capable of 25amps, his inverter will not run through this unit
Click here
the unit above does the same thing, but is only rated 5 Amp
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
