NinerBikes
May 05, 2015Explorer
jrnymn7 wrote:
As for EQ'ing once a month... I would let the batteries decide when they need to be EQ'd. I was going to do a Spring EQ'ing on mine, last weekend, but after being top charged occasionally throughout the winter, and then charged at normal Abs voltage for several hours, individual open circuit voltages were dead even across the bank, and SG's were all within 0.010 of each other... even the two 'prodigal' cells.
One thing I have noticed is higher Vabs charging results in lower resting ocv. There seems to be a sweet spot where both ocv and sg's respond well.
Bad form to use the term "dead" in any battery charging post, even if they are "even". "Almost all equal" in specific gravity would be better. About as proper as folks that used double negative speak in a sentence or a thought process as in "I am not unopposed to the idea".
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
