landyacht318
May 07, 2015Explorer
One can sit around and argue ideal voltages all day long, but the best value for each battery will be different and change as the battery ages, and depend on the depth of its discharges.
My screwy31 required rather excessive voltages to get the SG into the green via low and slow solar, 14.9absorption and 15.3 finish, and 16 volts for 45 minutes to 2 hours every 2 weeks to max out SG.
Yet when pumped upto and held a 14.7 for 2 hours via my 40 amp meanwell would do the same thing as the low and slow solar.
The hydrometer will tell you what your flooded batteries want and how they respond to your charging sources. Or you can go stick your head in the sand and drink the Kool aid and believe the marketing department of your charging source and thump your chest with the 'works just fine' mantra while trying to get others to agree with you.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
