BobsYourUncle's avatar
Dec 10, 2013
RV Windows. Dual AND Thermal Break. Do they make them?
I have been doing all kinds of research on double glazed RV windows.
Yes we all know we can get them, even though the airspace is only 1/4" or so.
But the big thing that is very important is the frames. The solid aluminum frames are brutal in cold weather. Don't need the fridge - just pack your food around the inside of the windows!!
Tomorrow will be one month on the road in my TT with the cruddy old single windows. I have packed thin foam insulation around them and all that but the frames are like a giant AC unit, radiating cold inside. Keeping the blinds shut helps a bit but....
I cannot find even one single bit of info on thermally broken RV windows. They make them for stick n bricks, lots of them, but RV's? doesn't seem to be any. I install a ton of T-break products on houses, but nothing for RV's
Even if they made the frames in vinyl instead of aluminum, but again, no info on that either.
These windows are nasty, really nasty. Cakes of ice all over them.
I know it is fluctuating from minus 32C to minus 10 or so but surely someone out there makes a decent RV window for cold weather.
Have any of you seen a thermally broken RV window? Or have any info on it? I can't find anything.
