84starmaster's avatar
84starmaster
Rv wiring stumper????
I am trying to figure out my wiring for my tail lights on my 1984 starcraft starmaster pop up. I have four wires coming out to the old taillights on the driver side. These are white which I know is ground, green which I know is for running lights, yellow which is reverse lights and red, which is turn/ stop light. I purchased LED taillights that have a five wire hook up. I hooked these up to a 12v battery and determined what the wires on the tail light control. Black is ground, white is reverse, green is running lights, yellow is turn signal and red would be brake. The issue is that the LED light has the turn signal and brake signal circuits separated, where the original setup was on the same wire, using a dual element bulb. When using a test light on the red wire from the camper, it will blink as it should when blinkers are on but give more power for brake light when brakes are applied. If I hook up this red wire to the LED light fixture on the blinker circuit the light will blink as it should but will light up like a brake light when brake is applied. This is just an amber turn indicator, I want it to just blink. I can take it lighting up when brake is applied because it does blink when brakes are pressed and turn signal on, but I don't get the red lens to light up for brakes like it should. Can I tie into the electric brake circuit to get my brake light in the rear? Please help, I will try to post a crude drawing of what I am talking about.,thanks
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
