D_E_Bishop's avatar
D_E_Bishop
RVs and the NEC
While I am probably opening a huge can of worms here, I would like to clear up a few things if possible.
The NEC is really a product of the NFPA.
The NEC or the Code is the National Electrical Code, it is neither a CODE(law or rule) nor is it National. In fact there are three states that have not adopted the NEC.
The NFPA is the National Fire Protection Association, prepared and funded in part by insurance underwriters.
The fact that RVIA(RV Industry Association) has adopted the NEC as the recommended standard for electrical installations in RVs, it has no requirement that RV builders must follow the NEC. It is not a AHJ.
This LINK goes to one mans interpretation of what the Code is, you can accept it or reject it but it is accurate.
Additionally, the Code does not and cannot require the builder of a RV park to install RV pedestals or how many or what capacity it must install. It only covers what pedestals are acceptable to the NFPA.
If this is to far off course, the Mod or Admin should remove it, that is the way it works.
  • While you guys are discussing, arguing and looking up technical things, Jakie is tossing a handful of wires for Amos to fasten somehow. I'm sure those guys are well versed in standards and codes.
  • rk911 wrote:
    AHJ's??
    Authority Having Jurisdiction. Building Department. Building Inspector.
  • I am curious since I served on two NFPA committees for 15 years. NFPA is a self funded non profit organization established in 1896 and has produced over 100 standards and codes addressing about everything concerning fire safety. And it may well be partly funded by insurance underwriters. But I have never heard that and am curious where to find that info.
    NFPA creates documents in the form of "standards" and "codes". You are correct that the codes are not law in themselves. But they are written in a format with the proper rigidly written language to be adopted as legally enforceable codes by state or local entities or AHJs. Standards are less rigid written and more intended as guidelines.
    Each standard and code has a committee of typically about 15-25 non paid volunteers who work in some way associated with that particular industry, meaning they have some expertise in the field rather than someone sitting behind a desk making up rules. In the case of the committees I served on there were representatives from the manufacturers of associated equipment, from manufacturers of associated control systems, from major engineer and consulting and construction firms, from insurance underwriters, and from the end user/customer/buyers of the products. Each group would have 2-5 members on the committee. In our case only 2 members from insurance. Prior to any proposed provision put into the codes and standards, there is a vote of members as to whether that provision is acceptable to all parties. It requires a majority vote to pass thereby preventing any individual party being able to install provisions that benefit that party without being acceptable by the majority. The end user likes more relaxed rules. Insurance likes more rigid rules. The others are typically somewhere in the middle. The final verbiage comes after much discussion and voting by all members.
    Additionally, the Code does not and cannot require the builder of a RV park to install RV pedestals or how many or what capacity it must install. It only covers what pedestals are acceptable to the NFPA.Additionally, the Code does not and cannot require the builder of a RV park to install RV pedestals or how many or what capacity it must install. It only covers what pedestals are acceptable to the NFPA.
    I hate to be contrary but, If the State/county/city has a building department that issues building permits and the State has adopted the NEC building code then it must follow the NEC Artical Part VI #551.71 as to how many, what size and where the pedestals are installed. If not they will not issue a permit and the power company will not hook up. It's just the way it works.
