wa8yxm
Apr 12, 2019Explorer III
The only question I have is how much does it eat (propane) it says run time at 25% load (175 watts) 3 hours.. That is not enough for a full charge on batteris that are at 50%. and also you can not use well you MIGHT be able to run a 60 amp converter (I'd limit to 45) Which will increase your time needed to recharge.
I do notice it shows both a "Throw away" and a 25 pound bottle. so is it 3 hours per throw away or per 25 pounder???? bid difference.
Still for 250.. Worth a look,
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
