time2roll
May 11, 2019Nomad
Ran the Ryobi first time today. Really like the light weight and the propane fuel. Seemed to be as quiet as my old Honda 1000 but it has been a while since that was sold. Anyway seemed virtually the same at idle but the noise level did not seem to ramp up as much as the Honda. Runs noticeably cleaner than gasoline.
Barely came off idle to power the 20 amp charger. Ran the Xantrex XADC-40 just fine for a solid 20 minutes putting 41 amps into the battery. Xantrex is PF corrected. Then plugged in the 35 amp WFCO. Was putting 38/39 amps into the battery maybe 20 seconds before the generator cut power and illuminated the overload indicator.
Looks like I might be swapping the Xantrex back in.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
