After drilling the vent hole for the tire stem he did not check for and remove any plastic cuttings that could have gone into the can. Why introduce them into your fuel system if you don't have to. Regarding the gas attacking the rubber tire stem. They are cheap and obviously easy to change. I don't see that as a problem when you compare the kind of problem 5 gallons of gas could be.
Having RV issues? Connect with others who have been in your shoes.24,378 PostsLatest Activity: Apr 12, 2026
