- GdetrailerExplorer III
Dog Folks wrote:
LarryJM wrote:
Dog Folks wrote:
Get the good metal cans that work well from the start for a few bucks more, rather than spending the time to make a cheap plastic unsafe.
Safety has no price.
Please explain EXACTLY what in that mod in the link in the OP makes it as you say "UNSAFE".:h
Larry
1. EVERYTIME that man uses a clipper or razor knife to remove elements, he is removing safety. He does this about four times in the first two minutes.
2. I personally would not trust the long term resistance to gasoline wetting the rubber tire stem.
Just my humble opinion. Don't claim to be an engineer.
#1. The items he removed has NOTHING to do with "safety" unless you think it is safer to never FILL the can in the first place which was two of the mods by cutting off the push in that prevents the darn nozzle from being removed in order to fill the can..
Try this, put your can out in 32F or lower temps and try to push that little tiny piece of plastic in so you can fill the can in the winter.. That plastic gets pretty darn hard at those temps..
He removed that darn little side button which makes you have to use a thumb to push in the button while trying to squeeze the handle. There is no need for that stupid locking button.. Meanwhile you are trying to hold a 5 gallon can with one hand and doing crazy things with your other hand that was not meant to do..
#2 Simple fix, buy a METAL stem and use O rings rated for alcohol/oils and if you want a valve in the stem use one rated for use in A/C units (those must survive refrigerant which has oil mixed in)..
There, ALL of your "safety" concerns fixed in one post.. - pasusanExplorer
Gdetrailer wrote:
This has been my experience also! :M
The EPA "carb" cans were NEVER designed to be "safe" for the USER.
They were designed to "save the world" of carbon fuel vapors.
In reality they are far more dangerous for the user AND the world since no matter how careful you are you ALWAYS end up spilling fuel all over the item you are attempting to fill.. Causing a greater risk of fire, wasted money in fuel and not to mention MORE fuel vapors ending up in the air..
Those new can manufacturers should be mandated to automatically give you lifetime hazmat cleanup kits..
The mods in the video are dead on and make the can MORE environmentally friendly by not spilling fuel each time you attempt to use it.
I personally have adapted older style spare spouts I had laying around and added replacement closeable air vents to mine.. Now they work better and are no longer a hazard to me and the environment.
Warning to those who want to do this mod... Read the comments after the video and you will see that the rubber valve stems do fail because they aren't meant for use with gas. - Dog_FolksExplorer
Larry
Just my humble opinion. Don't claim to be an engineer. - mboppExplorerI've picked up a few "old style" plastic gas cans at flea markets. I shy away from old metal cans, usually they have a lot of rust on the inside.
Old-Biscuit wrote:
But it is no longer SAFE
Looked at a 1 gallon gas can yesterday for gas/oil mixture for chain saw
Had to 'push' in on locking tab then 'push' down on spout before fuel could flow.
Tried it on a chain saw in store.....if it had fuel in can it would have: not flowed or have flowed all over
Easiest was just unscrewing/removing nozzle and just pour :S
Needless to say..didn't buy a new gas can
I personally have adapted older style spare spouts I had laying around and added replacement closeable air vents to mine.. Now they work better and are no longer a hazard to me and the environment. - LarryJMExplorer II
Larry - Dog_FolksExplorerGet the good metal cans that work well from the start for a few bucks more, rather than spending the time to make a cheap plastic unsafe.
Safety has no price. - TubaPeteExplorerI just loved the venting method. Solves a lot of problems.
Sort of off topic but it was my understanding that the EPA required all those changes not for your safety but because they have fixed so many sources of air pollution that gas cans without pour caps and open vents became a leading cause of air pollution. )Just how much pollution can gas cans cause?) - GordonThreeExplorerI picked up two EAGLE steel safety cans from Amazon during a 50% off sale. They're 6 gal and have a wide round base, short and squat so they're hard to tip over.
Only downside is the attached funnel has to be removed to refill the can, and I see that eventually busting the funnel as the plastic turns brittle from UV and hydrocarbon exposure. - coolbreeze01ExplorerI fixed all my pour spouts and added the valve stem vent to my diesel can.
Will vent my gas cans as I empty them. Sure eliminates the pain of pouring.
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 02, 2025
