dougrainer
May 15, 2013Nomad
Peg Leg wrote:
Do not replace it with a harder bolt. It's a shear pin, meant to break so it protects more expensive hardware.
WHAT more expensive hardware?????? It is NOT meant to be a "shear" pin. It is a BOLT that connects the driveshaft assbly to the motor assbly. The Motor assbly cannot create more torque to "break" any other part in the slide system. The slide just will NOT move if something stops the system from moving. The driveshaft bolts are just the weakest point in the slide mechanism. That is why they shear off. THAT is the word. They shear OFF, not because they are designed to do that, that is the term when they break off. Doug
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
