army_guy1's avatar
army_guy1
satalite connections
Hi folks,
I've got a question - I am running cable from sat dish (traveler three) under my slide out and up into the back of my entertainment center into an A/B switch. When I went to hook up the main line from the receiver to the A/B switch, I got a spark from the cable line. Could I have shorted something or is this ok?
  • Every time you use that A/B switch you are going to get a similar arc across its contacts. This will shorten its life unless you unplug the receiver before switching antennas. If you are using a SWM system, you also need to unplug the power inserter. Once you switch antennas with the A/B switch, power everything back up and all is good. I learned this the hard way!
  • That cable is a two way street. From the dish to the receiver it carries the television signal. From the receiver to the dish it carries power and instructions that the antenna needs.
  • I don't think that's an issue? I've seen that spark when the two wires touch. Might be why my receiver (211)says make all connections before plugging in.
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
