chalet05's avatar
chalet05
Satellite only works connected directly to DVR
I have a Winegard Carryout Portable Satellite. All of a sudden it will only work when connected directly to the DirecTV DVR. It will search and search but says it finds no satellite (signal strength screen confirms) when connected outside. Obviously there is something that can 'disturb' the outside connection I don't know about.
Any suggestions will be appreciated
  • robsouth wrote:
    Has it ever worked connected to the "outside"? I'm assuming that you mean a connection on the outside of the camper where one would connect cable TV and in some cases, a satellite dish connection is also available. If not, and you only have a cable TV connection, then it will not work using that connection. It cannot pass thru the rooftop TV antennae connection or a splitter. Let us know how you are coming along with the problem.
    I think robsouth has found the problem. I thought the OP was talking about an outside TV but now it makes more sense.
  • Has it ever worked connected to the "outside"? I'm assuming that you mean a connection on the outside of the camper where one would connect cable TV and in some cases, a satellite dish connection is also available. If not, and you only have a cable TV connection, then it will not work using that connection. It cannot pass thru the rooftop TV antennae connection or a splitter. Let us know how you are coming along with the problem.
  • Are both interconnected? If so are they both on same channel? Are you going to in port on Sat then out port on DVR to TV in port, then using the DVR remote only?
  • Right.
    Winegard to Direct DVR to television.
    It sounds like you are trying to run an outside TV with the Winegard cable hooked directly to the outside TV . That will not work.
  • Rollnhome wrote:
    The dish has to connect to the Direct TV box. You can not hook the dish directly to the TV. The box is what detects and reads the signal.
    In my case, the DirecTV 'box' is the DVR.
  • The dish has to connect to the Direct TV box. You can not hook the dish directly to the TV. The box is what detects and reads the signal.
